JMillerUA6
Grillin' rape steaks
P1382 - Cylinder Position Sensor No Signal
Could have been found easily if you would have searched for it.
the ulev may have the cyp pin different at the ecu. there should be pin outs on here some where search and it should help you if all else fails buys a haynes and it has the wiring diagram for both ulev and normal vtec.the ulev may have the cyp pin different at the ecu. there should be pin outs on here some where search and it should help you if all else fails buys a haynes and it has the wiring diagram for both ulev and normal vtec.
