Idle Problems
Quintb2000
Louisiana
Hey guys
Ive searched and ive searched and searched. Absolutely nothing has fixed my problem. I have a loping idle and it will not go away.
Here is the list of things ive done...
Ive tried
Checking everything for vacuum leaks. Carburetor cleaner method - no leaks
Ive changed out the valve 2x Junkyard and brand new - disclaimer - the brand new one was cheap off amazon. Don't know if that matters
Ive reset the idle multiple times.
Ive let the car reprogram itself by pulling the backup fuse each time.
This is my daily and i gotta get this straight
Thoughts//
95Tech
Sanatobia
Replace your EGR valve and clean the port holes going through it in the intake manifold. I also seen where the 2nd clutch pressure switch could cause sporadic idle issues.
Quintb2000
Louisiana
Completely took down the intake manifold and cleaned it. Everything back together. Still lopes. Will reset the ecu and it does great for about 30 minutes then it comes back.
