Sleeper Cell
No more CG Squad!!!
My car is still lowered on coilovers. It's hard for me to know exactly what range to specific degrees since everyone's car has different alignment specs and ride heights, but I was able to determine that there was about nine degrees or so of adjustment in total. I will say that given the length of the arms, they are probably biased towards correcting camber, however there is tons of adjustment in them regardless, so you can go pretty damn negative.
I had 19mm of thread inside the turnbuckle when I got the -5.5 degrees at my ride height. I have been informed that the minimum safe amount of thread is 12.7mm inside the turnbuckle. That means you'll have an extra 12.6mm (6.3mm per side) of thread to play with, which should put you past -6 with these arms alone. If you get an upper control arm, I'm thinking you should be able to get even more negative camber, although it's not recommended.
