Lx sedan h23a
TheNewGuy
Ayden, nc
Hi guys, I have a 2000 LX 2.3
I'm looking into swapping my f23a for an H23a and know it's pretty much all plug in play as for as installing. With the exception of maybe a motor mount. But as far as performance should I just use my stock wiring and ecu or do I have to use the wiring and ecu for the h23?
Check with bairdandrew77 and Jordan_H, they are doing/have done an H23 swap.
TheNewGuy
Ayden, nc
This is what the engine is coming with is there anything elts I will need the car is automatic and I'm keeping it that way. Will there be any issues with wiring or anything as far as connecting in car??
Complete engine
AT transmission
wiring
ecu
Intake manilfold
Throttle body
Alternater
Power steering pump
Starter
A/c compressor
distributor
fuel rail
injectors
exhaust manifold
Steadycrusin401
rhode island
It is pretty much plug and play but you have to make a distributor harness adapter. As for mounts you can still reuse your oem mounts if they're not junk. Just make sure you have the h23a driver side engine bracket.
