SykVSyx
Not knocking your choices in products, but the fact that you were able to outfit your audio setup for $300 is not going to give you alot of flexibility. Doesn't mean what you want to use isn't good enough, but perhaps the money could be put to some better use. As Wildman stated, a 2Ohm sub would give you more flexibility rather than a 4Ohm. Not sure what that Alpine amp is rated at, but if that sub is rated at 270w, then your amp should have a max output rating of the same/close to.
Never used a D-Class amp personally, I would have suggested a Multi-channel/Mono amp set up myself, but that's personal preference. Since you are pretty much just upgrading your stock speakers and adding a sub, it's not bad for the budget you're working with. If you're patient though, and you save up some more, you'd be surprised at how much more option you'll have for your setup. Highly recommended that you give it some more time and try and put aside some more towards your budget.
