So recently I've been noticing some massive leaks under my motor. Looks like I put the rear main seal in slightly crooked when I did the 5 speed swap so that had to be taken out and replaced. Then I noticed my oil pan bolts were loose so I tightened those up and the leaks stopped. Now, when I had these leaks I was around 10 psi of oil pressure at idle at a light and about 70 to 80 when highway merging etc. I changed the oil and added a larger wix oil filter and switched to Pennzoil 5 w 30 synthetic. I now get about 40 psi at idle and sometimes over 100 psi when driving spiritedly . Can anyone elaborate on why this is? I would also like to know if this is too much oil pressure for the f23 and could this damage the motor in the long run? Thanks again.
Sent from my LGMS210 using Tapatalk
