Parts for Timing Adjust Checklist
305S0L
Miami, Fl
6GA need your input:
Please advise if I am complete or am missing parts for my 2002 f23 Timing Adjustment:
-Timing Belt
-Balance Shaft Belt
-Water Pump
-A/C Belt
-Power Steering Belt
-Balance Shaft Tensioner
-Timing Belt Tensioner
-Engine Crankshaft Seal Front
-Camshaft Seal
-Balance Shaft Seal
Thanks! :party52:
justin_l_
Southern Maine
I think I had to pull the valve cover to pull the upper timing belt cover, so if that is worn you may want to replace that as well. If you don't have the tool to hold the crank you may want to invest in one. Other than that it looks like everything.
Like that dude, valve cover gasket.
Normal shop guys wouldn't...no fluids?
