GoldnKnight22
TWM:TLMF
^^ props to that response.
hey man it looks nice......i like it......i did the same sort of thing to mine but it was black and tan themed
It's ok. I'm from neither.
Usually I do give constructive criticism without flaming, but this thread kinda blew a fuse.
eDub, I'll have to give you props again for taking the opinions and criticisms in stride as well as pristine execution on the finish. It really does look meticulously detailed.
I take it for the dash, you used the primer, then adhesion promoter spray, paint, then the flat clear coat...? Any prior sanding?
diddo with the sentiments, emphasis on the 'H' not working for me. final product is leaps and bounds better than anything i could pull off.
the door section that's black, is that different material or just the stock piece painted black? same question for the center armrest.
and i'm pretty sure i've seen you rollin around plantation when i leave work, edub; you mind hooking up a local with your expertise?
hey did u removed the dashboard wen u did it or just mask everything off???
