Go!
EDIT: Check my most recent post for an update on the situation, thank you!
This might be close to the end of my 2001 Accord. It has an array of problems that I feel like are going to be an expensive fix. I don't know if they are so I am going to give you all the details right now, and if you have any help or ideas of what it might be, I would greatly appreciate it. 225k miles, btw.
When I try to start it, it reluctantly wants to start and usually takes a few seconds to start. Once it does start, the RPM gauge sits down to around 500-700 rpm with a VERY rough idle.
When I get driving it is fine, but once I stop @ a red light, the RPM dips again and rough idle starts. This is when my check engine light starts blinking at me until its green and I press the gas pedal.
Those are the main issues, but there is also one more. After I have driven to my destination, park, and turn off the car, If I go back to turn on the car within an hour (ie while its still warm from driving??) It will be VERY hard to start and dies on me once I do get it started. On the chance that it does start and I can through it into reverse, it dies if I dont floor the gas to get RPMs up.
TLDR; Do you know a fix to a very rough idle where it dips the RPMs so low the car dies?
Thanks friends!!
Thanks friends!!
