If you don't use cruise control, why did you install the module? I think it would look better without it. Either way, looks good!
noob question, but how/where do you check to see if your car is dual airbag or not? I want that wheel!
If your car has driver & passenger airbags, you should have 'SRS' embossed on the airbag cover on the steering wheel, and on the bottom right-hand corner of the dash panel above your glove compartment (which you would have if your car is dual restraint).
really? I thought all cars had that..im pretty sure my 99 does too..but if you say so than awsome..But I thought you have to open the cover on the bottom of the wheel to see the plugs how many you have 1/2?
its about the dual stage airbags...it either inflates fast or slow, depending on impact speed determined by the sensor. old airbags inflate at one speed, whether youre hit at 15mph or 50.If your car has driver & passenger airbags, you should have 'SRS' embossed on the airbag cover on the steering wheel, and on the bottom right-hand corner of the dash panel above your glove compartment (which you would have if your car is dual restraint).
we all have dual airbags...its that the 01-02s (maybe 00s, can't remember) have the dual stage airbags and therefore the correct plugs to work with the rsx/s2k/civic/etc bags.
