Hoff Daddy
I have a 99 f23a1 accord with 205k mi on it. This car runs very, very good. Compression is strong, maybe a little better when warm, but the rings seem to be in decent condition for the milage. So the only problem I could point out is the rings are slightly worn and that may contribute to a small amount of oil consumption in these cold months. Oil consumption isn't bad, usually if I can actually get the oil to read right then by the time it's ready to change oil the oil level will move just slightly below the top line and I don't have to add any oil. The thing is though is I can never get the dipstick to read right. The car must be stone cold to get a read, otherwise the oil will barely touch the dipstick even if the car has sat for 10mins. It really does not make any sense unless it's taking forever for the oil to drain all the way down and my block would have to swell a lot. So next oil change I'm going to use some of that oil system clean out stuff, maybe there's a blockage. The last thing that catches my eye is that the oil light will come on for about 3 seconds after I start the car and I will never see it again. Once again this car has me dumbstruck and clueless.
