So the other morning I tried to start my car (2000 4cyl SE sedan), and it would turn over, just not fire. I first thought it was the battery since it was a very old and weak one, so I replaced it with a brand new battery. After that, the problem didn't change at all. Luckily, I was working in low light, and saw some arcing in the distributor cap when I tried to start it. So last night I replaced the distributor cap and ignition rotor. It helped...but there is still another larger problem. When I tried to start it, it was getting spark and fuel (I could smell gas, and some cylinders would ignite every so often), but would not run at idle. It seems to me that the timing is somehow off...since it was so rough when trying to start it.
Any help on this would be very much appreciated, I need this car to drive to work every day! It's weird how this happened all of the sudden.
