camjohns
2000 honda accord 3.0 ex
As i started in to do the timing belt, i found the lower bolt on the power steering pump to be stripped and unable to be loosened. I attempted with a 12mm socket with no luck as it just had no bite, i tried smaller, but would not fit. So now im stuck and trying to figure out what the next step is. The 2 upper bolts came off fine with no issue.
What options do i have as it is a tight space and is pretty difficult to get anything in their to bite it?
can the other side of the bolt be accessed with the removal of the intake manifold? or is that built in?
thanks for the help!
