What maintenance have you done lately?
deucescorner
montreal
So my car came out of storage in end of April, and this is already what I've done so far:
Driver side outer tie rod
Driver side Upper table
Driver side Lower balljoint
A/C Line
Refill Freeon
Timing Belt
Water Pump
Accessories Belt
Power Steering Pump
...still to come:
Passenger side outer tie rod
passender side upper table
passenger side balljoint
Both front shocks(with my luck all 4 shocks)
Front pads and rotors
Tensioner pulley
plugs and wires
is it just me or do you guys also sometimes feel that with all the money that we've put in to maintain our cars that we're better off getting something newer but at the same token, with all the time/money we've put in, it's hard to just let it go, especially what I would get for the car.
ps my beater is also acting up on me:(
Need to recharge the A/C at some point, but I dont use it so I can put it off a little longer. Oil change this weekend, maybe some plugs.
BPAccord
*DAIGAKUSOTSU*
So-Cal LOve/ O.C
Timing belt replaced
Water Pump
AC Lines welded and Freon Refill
Exedy OE Clutch Replacement
New front Axles replaced
IAC Valve gasket seal replaced
O2 Sensor Replaced
Catalytic Converter Replaced
Spark plugs and Spark plug wires
This since February....gotta say it worth it though...car drives so smooth
cajun
AL
deuces - that's a lot of front end work. How may miles? Roads rough up there or something?
deucescorner
montreal
I've got alot of miles on my car but still doesn't excuse the consistency of my suspension work.
Problem is that I have 225/35 tires withe Montreal roads. I think that we we're actually voted worst roads in North America a few years back.:(:(
GoldnKnight22
TWM:TLMF
NH
Haven't had to do any maintenance really... oil change and I need to replace spark plugs.
Past due for the timing belt tho...:eusa_wall: CrAp!
cajun
AL
Just got OEM front brake pads in the mail. Will do next week.
Will probably do cap + rotor + wires + plugs soon. Are you guys doing plugs changing them before the 105K interval? I'm only at 60k, but figure it might be worth the time/money since I'll be doing the work.
