6 speed swap parts list! (organized)
storms
Okanagan, BC Canada
I have some time on my hands due to surgery so went and redid the list and organized it into categories, so you can easily check them off as you buy!!
6 Speed swap parts list!
1) Transmission mounts, 03CL-S
50805-S3M-A03 front Mount $39.79
50806-S3M-A03 Rear Mount $56.26
50809-S3M-A00 Beam $56.78
95701-10035-08 Bolt (3) $2.64
95701-10085-08 Bolt (2) $3.38
90371-S87-A00 Nut (4) $4.12
50803-S3M-A00 Washer Front mount $0.95
2) Starter 7th gen Accord/ 03 CL-S $165-300
3) Clutch Assembly, Hydraulic system
46965-S6A-013 TANK ASSY $35.65
46922-S3M-A01 ACURA MASTER CYLINDER $60.44
94050-08080 NUT (8MM) (2) $0.19
46941-S5A-003 Connector $7.31
46971-SDA-A01 TUBE $4.78
46972-S6F-E01 CLAMP, (2) $17.84
46960-SDA-A04 PIPE A, $9.02
46962-SDA-A01 RUBBER (2) $4.84
90658-759-003 CLIP (2) $2.13
46995-SDA-A02 BRACKET A $11.02
90651-538-000 CLIP (2) $3.06
17116-PWA-000 COLLAR (2) $1.55
21724-RAY-000 RUBBER (2) $3.10
90001-P7J-000 BOLT, SPECIAL (6X25) (2) $1.05
46961-SDP-A01 HOSE $13.88
46968-SDP-A02 BRACKET B, $10.59
93403-06016-08 BOLT-WASHER (6X16) $0.65
46970-SDP-A01 PIPE B, $4.50
46977-SDP-A01 CLAMP $2.94
46930-S3M-A01 CYLINDER SLAVE $66.43
4) Gear shifter 7th gen Accord and CL-S depending on which one you chose!
CL-S Shifter
54100-S3M-A01 LEVER SUB-ASSY $67.85
54310-S3M-A01 WIRE, CHANGE $125.86
54357-SF1-003 Clip (3) $3.44
90555-SF1-000 WASHER A, SHIFT WIRE (1.6MM) $1.96
90556-SF1-000 WASHER B, SHIFT WIRE (0.5MM) $1.45
90557-SF1-010 WASHER A (1.6MM) $1.96
90558-SF1-000 WASHER B, SELECT WIRE (0.5MM) $1.45
94201-20350 PIN, SPLIT (2.0X35) (2) $0.52
94201-20220 PIN, SPLIT (2.0X22) (2) $0.52
54118-SC2-000 WASHER ASSY $3.16
54116-SV4-000 PIN, LINKAGE $1.93
93404-08035-08 BOLT-WASHER, 8X35 (4) $0.76
54119-S30-003 COLLAR, FLOATING (4) $2.00
54117-S6M-003 RUBBER, FLOATING (4) $2.16
7th gen Accord Shifter
54100-SDP-A01 LEVER SUB-ASSY $51.13
54310-SDP-L02 WIRE, CHANGE $98.45
90558-SF1-000 WASHER B (0.5MM) $1.45
54118-S10-000 WASHER ASSY $1.91
94201-20220 PIN, SPLIT (2.0X22) $0.52
5) Clutch pedal and Brake pedal from 6th gen accord I4 get used from auto recyclers!
Below are the 2 switches for the clutch pedal!
35710-SE3-A01 SWITCH ASSY., CLUTCH (INHIBITER) $35.57
36760-SM4-003 SWITCH ASSY., CLUTCH Pedal $22.29
6) 7th gen Accord Flywheel
I got a used one for $100, New retails for about $500
90011-PGE-000 Flywheel BOLT (12MM) (8) $2.40
7) Clutch
22105-PGE-315 CLUTCH SET $237.58
90034-PRC-000 BOLT (12 POINT 8MM) (6) $2.40
8) 6 speed Transmission, either 7th gen Accord, 03 Acura CL-S or 04-08 TL-S
Price varies from $650-2500!
9) Richie control module, this enables your instrument cluster to work, V-Tec as well as reverse lights and reverse lock out! $600
10) Extras!
Shift Knob of your choice $20+
90165-S3M-A00 BOLT, FLANGE (10X32) (3) $1.44
This bolt is used on your front engine mount, it is required simply because it is 3 millimetres shorter then your stock 1 and won't bind up the ring gear on your flywheel since it is larger then your torque converter! You can replace all 3 or just the 1!
2000BlackCoupe
where
total cost minus tax is $2,938.18. considering each of the multiple purchases are for total cost and not individual (ex. "54357-SF1-003 Clip (3) $3.44")
storms
Okanagan, BC Canada
Yes they are total cost, so if it says (3) $3.44 then that is what you pay for all 3!! and remember this is providing you buy it all new!! I would not suggest it LOL!!
storms
Okanagan, BC Canada
Also on a side note not all the nuts and washers that I have listed needs to be bought, for example when you buy the wire change assembly in the shifter section some of the washers, nuts and bolt are already included. I just added them so that all parts are listed!
SykVSyx
Tee Dot Ohh
This will help in checking off the list of stuff that I got from Chris awhile back.
Appreciate the attention to details, Colin.
Thanks for sharing.
This makes the 3rd parts list on the site lol. Mine is posted somewhere in my swap thread, it has everything I used.
Can this be done in the I4 or is it for both?
Can be done in i4, but not recommended. There have been a few discussions on that.
