6 speed swap parts list! (organized)
Jdmj30a1
Oxnard
Whats the difference between the cl clutch master cylinder and the civic or 4 cylinder CMC other than price is it stronger?
spacemonkee23
Placentia, CA
Just adding a quick FYI here...
If you are looking for a donor ’03 CL-typeS, the seventh digit of the vin number tells you the transmission. I found it helpful on auction websites that post the vin.
Seventh digit:
1 = 6MT
2 = Auto
6MT = 19UYA41603A000316
Auto = 19UYA42413A015145
Happy hunting!
Tokenblackguy
Renton, WA
I have some time on my hands due to surgery so went and redid the list and organized it into categories, so you can easily check them off as you buy!!
6 Speed swap parts list!
1) Transmission mounts, 03CL-S
50805-S3M-A03 front Mount $39.79
50806-S3M-A03 Rear Mount $56.26
50809-S3M-A00 Beam $56.78
95701-10035-08 Bolt (3) $2.64
95701-10085-08 Bolt (2) $3.38
90371-S87-A00 Nut (4) $4.12
50803-S3M-A00 Washer Front mount $0.95
2) Starter 7th gen Accord/ 03 CL-S $165-300
3) Clutch Assembly, Hydraulic system
46965-S6A-013 TANK ASSY $35.65
46922-S3M-A01 ACURA MASTER CYLINDER $60.44
94050-08080 NUT (8MM) (2) $0.19
46941-S5A-003 Connector $7.31
46971-SDA-A01 TUBE $4.78
46972-S6F-E01 CLAMP, (2) $17.84
46960-SDA-A04 PIPE A, $9.02
46962-SDA-A01 RUBBER (2) $4.84
90658-759-003 CLIP (2) $2.13
46995-SDA-A02 BRACKET A $11.02
90651-538-000 CLIP (2) $3.06
17116-PWA-000 COLLAR (2) $1.55
21724-RAY-000 RUBBER (2) $3.10
90001-P7J-000 BOLT, SPECIAL (6X25) (2) $1.05
46961-SDP-A01 HOSE $13.88
46968-SDP-A02 BRACKET B, $10.59
93403-06016-08 BOLT-WASHER (6X16) $0.65
46970-SDP-A01 PIPE B, $4.50
46977-SDP-A01 CLAMP $2.94
46930-S3M-A01 CYLINDER SLAVE $66.43
4) Gear shifter 7th gen Accord and CL-S depending on which one you chose!
CL-S Shifter
54100-S3M-A01 LEVER SUB-ASSY $67.85
54310-S3M-A01 WIRE, CHANGE $125.86
54357-SF1-003 Clip (3) $3.44
90555-SF1-000 WASHER A, SHIFT WIRE (1.6MM) $1.96
90556-SF1-000 WASHER B, SHIFT WIRE (0.5MM) $1.45
90557-SF1-010 WASHER A (1.6MM) $1.96
90558-SF1-000 WASHER B, SELECT WIRE (0.5MM) $1.45
94201-20350 PIN, SPLIT (2.0X35) (2) $0.52
94201-20220 PIN, SPLIT (2.0X22) (2) $0.52
54118-SC2-000 WASHER ASSY $3.16
54116-SV4-000 PIN, LINKAGE $1.93
93404-08035-08 BOLT-WASHER, 8X35 (4) $0.76
54119-S30-003 COLLAR, FLOATING (4) $2.00
54117-S6M-003 RUBBER, FLOATING (4) $2.16
7th gen Accord Shifter
54100-SDP-A01 LEVER SUB-ASSY $51.13
54310-SDP-L02 WIRE, CHANGE $98.45
90558-SF1-000 WASHER B (0.5MM) $1.45
54118-S10-000 WASHER ASSY $1.91
94201-20220 PIN, SPLIT (2.0X22) $0.52
5) Clutch pedal and Brake pedal from 6th gen accord I4 get used from auto recyclers!
Below are the 2 switches for the clutch pedal!
35710-SE3-A01 SWITCH ASSY., CLUTCH (INHIBITER) $35.57
36760-SM4-003 SWITCH ASSY., CLUTCH Pedal $22.29
6) 7th gen Accord Flywheel
I got a used one for $100, New retails for about $500
90011-PGE-000 Flywheel BOLT (12MM) (8) $2.40
7) Clutch
22105-PGE-315 CLUTCH SET $237.58
90034-PRC-000 BOLT (12 POINT 8MM) (6) $2.40
8) 6 speed Transmission, either 7th gen Accord, 03 Acura CL-S or 04-08 TL-S
Price varies from $650-2500!
9) Richie control module, this enables your instrument cluster to work, V-Tec as well as reverse lights and reverse lock out! $600
10) Extras!
Shift Knob of your choice $20+
90165-S3M-A00 BOLT, FLANGE (10X32) (3) $1.44
This bolt is used on your front engine mount, it is required simply because it is 3 millimetres shorter then your stock 1 and won't bind up the ring gear on your flywheel since it is larger then your torque converter! You can replace all 3 or just the 1!
Thank you so much for this list! I noticed not to many are performing this swap. Not sure why not, it seems like a cheap, really fun machine! The auto tranny sucks, this seems like a much better replacement for my V6 3.0L vtec! When that motor dies, I will look for a 3.2L.
How do you guys feel about the AEM series 2 EMS in place of the "Richie Controller?" Sure, its 1200.00, but you get so much with it!
I am about to do this myself in the next 2 months, wish me luck!
The Tokenblackguy
"I played way too much need for speed and have too much fun money not to go fast!"
ajperlotte1
Athens
CL-S Shifter
7) Clutch
10) Extras!
Can this assembly be used for a 1992 honda accord.
Tigmactor
Kalamazoo
The Tokenblackguy
Were you able to figure out everything with why EMS series 2?
Bigshaf
Nigeria
This makes the 3rd parts list on the site lol. Mine is posted somewhere in my swap thread, it has everything I used.
Can be done in i4, but not recommended. There have been a few discussions on that.
Hello,
I know it's a very very old thread;
I'm new to this forum
I just signed up to ask this question:
Is there any 6 speed Manual tranny I can pair with an F23 engine in an Accord 2001?
It actually came stock with a 5 speed manual tranny.
The engine gets so noisy that I always double check to make sure it's in fifth gear.
Thank you
604ACCORD
Vancouver BC
nope you need either f23, h22, h23 or fb20 transmission. They are all 5speed your best bet would be to find one with lsd
You'd have to swap to K series to get a 6spd 4cyl. But that's a whole other animal, only seen one person attempt it.
Tito_CG3
California
Ok so I am doing the 6 speed swap on my 1999 AV6, and I am going based on this part list posted here. In this part list it says I can use the 7gen 6speed transmission so far so good, the thing is that the 03 CL-S transmission mounts don't bolt up on the 7gen 6speed transmission, so what mounts should I use? Any help will be appreciated. :goofy_batman:
