it is. black gold.
hmmm you think the crappy oem jack is safe enough to use? or should i invest in those wooden ramps??
nah use the oem jack
nah use the oem jack, ebrake is not required. Just be careful
I wouldn't trust that shiet. No way am I crawling under my car with the scissor jack holding it up.
It's more tippy than a 5' girl with 44 double d's.
I prefer to do it myself. It's much cheaper and plus, you can actually take your time and let as much old oil drain out as possible. I'm sure a shop would probably do an oil change in 30 minutes, when the proper way would be to let the oil pan drain for 30 minutes. You can't get all the old oil out but it's always best to get out as much old oil as possible.
