5sp Swap wiring/ecu problems
nwcg3
seattle
Funny, I am in the same spot as you. I am about to work with the master plug wires to see if it turns over. If so , great.
Then i need to sort out the clutch safety switch. I thought it was only a factor if you used cruise control?
Any ideas yet? Anyone?
Varnell
Charlotte, NC
You can bypass the Clutch Safety Switch, but I don't recomend it. The wire is blue with a white stripe. It needs to be soldered to the switch on your clutch and also to the ecu.
