ppl are telling me that it might be my compressor but I hear it and feel it engaging when i turn the a/c on. Others have told me that it might be my a/c filter.
Could a dirty a/c filter really cause this or do i have another leak. I know i should've went back to the mechanic right away but i've been too busy.
Any thought?
No, a dirty filter would not stop cause that. You said you feel the compressor engage. Does it stay on? If it does you have freon in your system, although it may be getting low due to a slow leak. If not, the compressor clutch will engage and then disengage b/c the compressor has a low-pressure cut-off.
The obvious answer is - you need to go back to the shop and have the system pressure checked. Also, you mentioned that you would check the cabin filter by opening the glove compartment. You may already know this, but you have to actually remove the glove compartment in order to get to the two filters. If you're going to go through the trouble you might as well put in new ones.
