JMillerUA6
Grillin' rape steaks
Do you know what blow by is?? Blow by is due to failing piston rings causing oil to be forced into the crankcase after explosion in the combustion chamber.
Oil spitting out of the oil filler while the engine is running with the cap off is normal.
SO, like Greg said, stop running the engine with the oil cap off and your problem will be solved.
Oh yeah, change you oil.
