Correct LED beam angle for door courtesy lights?
robollama
I know the right size LED to get for these (168), but I'm not sure what beam angle to get? 360? 180? 90? 220? 120?
Any help here?
Chris Vu
So*Cal
Re: Correct LED beam angle for door courtesy/step lights?
wouldnt 360 be best so that the light spreads more evenly so that theres no hot spots ?
Madelinot169
Quebec, Canada
I just bought a kit off ebay, changed the lights in the doors (Coupe) the 2 lights on roof towards the front and the dome light for some UV L.E.D's and i think it cost me like $40, and it loooked pretty awesome.
Bax
It really doesn't matter too much for the courtesy lights, 360 being the best though obviously.
pics?
robollama
I just meant the courtesy lights on the doors. So no need to worry about hotspotting
I've already replaced my dome and map lights with white LEDs, and I loved them so that's the reason I'm now adding the courtesy LEDs.
pics?
Hmm.. You don't think it'll shine up towards you too much when you open the door?
i believe mine are 120 degree, and they are adequate.
anything with 200+ degree coverage will probably end up looking dim (that is, a single LED with a visible "spread" of that much).
robollama
click on the pic in my sig to see my leds.
EDIT: here is what i have in the doors: http://www.superbrightleds.com/cgi-...n=DispPage&Page2Disp=/specs/WLED-x.htm#photos
i can't remember if i got 90 or 120 degrees, though. i think i got 120.
thanks and nice ride man :thumbup:
Guess after both of you guys saying 120, I'll go with that.
Bax
Thank you. :peace:
Good choice. and get the ones i linked to, as the bulb only has one led. Anything too bright will look weird, as the courtesy lights aren't really meant to be so exaggerated.
robollama
Thank you. :peace:
Done. Just bought them :lolrun:
