Russianred
Snail Spools You!
Good luck man!
Well today hasn't went quite as planned... I woke up late and didn't even get to deposit my pay check in the bank. Then I went to the salvage yard to look around to see if I could find any 96-00 preludes or accords for donor parts. But everything they had up there was a mangled mess of metal and and almost all of them were missing the interior parts. So I didn't even fool with going to pick up the F22. Basically I am going to chill out till next weekend. Oh and a few more questions should I just get new hydro lines, master cylinder, slave cylinder, and starter?
Sup,
Well guys I've located most if not all parts for my auto to manual swap.
This is my approximate est. for the parts and were I found them.
Majestic Honda
Master cylinder and anything that has to do with it including nuts, bolts, and hydro lines. That is including stuff for the slave cylinder as well.
approximate cost 250
Clutch pedal, bracket, sensors, nuts, bolts, and the brake pedal also.
approximate cost 180
Shifter assembly, shift cables, nuts, bolts, seals, shift knob, and boot
approximate cost 240
From TAS auto parts
R/H C.V. axle 80
L/H C.V. Axle 80
5 speed tranny mount 90
ACT flywheel 310
OEM clutch kit 140
Short shift adapter 50
The 5 speed transmission, starter, and ECU, I have found on Ebay
5 speed transmissions generally are 350-700
Starters are generally 150-275
ECU are generally 150-300
I personally don't like fooling with Ebay, but if I have to I will resort to Ebay. I am sure if I look hard enough locally I could find the tranny, starter, and ECU. I am sure I can find the 3 wire VSS at a local junkyard and my step dad can get the tranny fluid for around 4 bucks a quart.
Well guys let me know what you think and if anything is missing.
Thanks
