Gauge lights and trunk lever!
search "illumination" in this subforum.
there is only one correct way to connect the orange wires behind the head unit.
metrick1235
Georgia
^ correct... if you do it wrong you will blow fuses and multiplexors constantly... Some stereos have two orange wires.. my dvd one did and it popped the fuses the first few times till i figured it out.... sounds like you have it all spliced.. i would buy the correct wiring harness and do it again with wirebutts and shrink tape...
vict0rydew
NC
Check your fuses, and replace any burned ones
Did you leave the battery hooked-up when you did stereo/sub? You shouldn't have if you did.
If replacing fuses doesnt solve the problem chances are you might need to replace the whole multiplexor unit.
Engine Bay
Passanger
Drivers
Thanks this will help a lot!! And yeah me and my buddy made sure to unhook the battery while hooking everything up :thumbsup:
vict0rydew
NC
When my dad had the radio installed the same thing happened. No lights on the cluster, A/C controls, not even on the shift panel (auto) I searched it up and had to bridge two cables on the cluster together and voila! Just no dimmer control.
Yeah this is exactly what has happened! I think i will definitely have to fix it the right way though with a new mulitplexer system
