a compression test *should* tell you all you need. if all of them are low (120 range) then the rings are bad. if youve got low compression in just one cylinder it could mean that piston has bad rings, BUT it could possibly be a hole in the head gasket letting everything into the coolant passages.
get one done, and tell us what numbers you get. good luck
