JOEYSACCORD
so today i scaned my ecu and its throwing a p1259 code..vtec right..so im gonna go clean out the solenoid..see wut happens???? and yea i checked my oil personally clean as a whistle
Should probably double check the VTEC pressure switch before loading a solenoid into the parts shotgun.
You'll need a multimeter to do this:
VTEC Pressure Switch Diagnosis
1. Measure the resistance across the VTEC pressure switch terminals (has the round 2 pin connector), it should read something. Anything under infinity or "OL" is good. OL would indicate an open circuit in the switch, replace it.
2. Check for 12V between pin 2 (BLU/BLK wire) and ground (engine block). If none, there is an open or short to ground between the switch and ECU.
3. Check for 12V between pins in the switch connector (wire harness) terminals. If none, there is an open in the ground wire or a corroded connection. The ground is on the right side of the upper intake manifold (opposite of throttle body), next to the intake air temp sensor.
If all checks out, grab a known good ECU and recheck.
VTEC Solenoid Valve Diagnosis
1. Measure resistance (Ω) between terminal on solenoid and ground (engine block). Should have 14-30Ω. If no, replace the solenoid valve.
2. There are some other diagnosis steps, but it's pretty in depth and you need special tools.
should probably double check the vtec pressure switch before loading a solenoid into the parts shotgun.
vtec pressure switch diagnosis
1. Measure the resistance across the vtec pressure switch terminals (has the round 2 pin connector), it should read something. Anything under infinity or "ol" is good. Ol would indicate an open circuit in the switch, replace it.
2. Check for 12v between pin 2 (blu/blk wire) and ground (engine block). If none, there is an open or short to ground between the switch and ecu.
3. Check for 12v between pins in the switch connector (wire harness) terminals. If none, there is an open in the ground wire or a corroded connection. The ground is on the right side of the upper intake manifold (opposite of throttle body), next to the intake air temp sensor.
If all checks out, grab a known good ecu and recheck.
vtec solenoid valve diagnosis
