Ok, started my led project, here are some pics
Zero-Defect
Clips break, that's why there's ebay lol... and if you're really lucky there might be some local junkyards with spare parts
H-town_Ryda_06
Screwston Tx
guys everything you need to know to get proper LED gauges is here
http://v6performance.net/forums/showthread.php?t=148766
I took my own mistakes + the mistakes of those on this thread and here are the results
I spent several hours tweaking everything to remove the hot spots, etc
ill be making a full DIY when i have some free time ( 2nd year medical student)
hey so i have a stupid question... when reading thru these diy led threads i see u use red/clear tape to make needles red on guage cluster.. my question is where did u find this tape and can u specify what brand/type to use (or mayb a link) cuz i been searching alot of stores and can only find red electrical tape and red duct tape but no transparent red tape... help plz... thnx
thejameshimself
Houston
Hobby Lobby or equivalent. If you scrape them clear you can probably use red tint spray or stained glass spray.
shenaniganz08
Los Angeles
Dont listen to him, dont EVER remove the paint on the needles.. thats how I screwed up my first set, and I had to purchase a new set from a member.
The paint that is used by honda has the properties of being able to spread the light out evenly on the needle. IF you remove the paint, you will have a needle that is very bright at the center, but will have really crappy light spread ( the problem is really bad on the speedometer needle which is the longest)
The tape I used is clear red tape from a hobby shop. It has reflective flakes in the tape that makes the red brighter, than normal clear red tape
I think its used for model balsa wood airplanes, thats all the info I have on the tape.
Zero-Defect
Actually, you can listen to him. If you apply reflective vinyl to the rear of the needles, it will distribute the light all the way to the tip. That being said, I personally think it's up to the car owner whether they want the light all the way to the tip or not.
ejreams
Fort Collins, CO
Is it better to have a larger viewing angle?
90 vs 120?
I was thinkin maybe I'd buy some WLED-x's 9.9k's
for the cluster, any advice?
Zero-Defect
As some of you may know, I'm always changing my mind on how I want my cluster. Well my car's goin to the body shop tomorrow (minor accident, no worries), but got a pic of how my cluster is right now, thought you guys might wanna see
What do you guys think of the light distribution?
