GoldnKnight22
TWM:TLMF
Hey Rick, nice to hear from ya. Thanks.
UPDATE: So last night I got the wires through one of those bitches. OMG it sucked. Rick, you hit the nail on the head, the friction is the biggest problem. And the fact that the tubing was pretty damn tight, not much room for the double-12awg wire to fit through there. The upper grommet end still isn't fitting back into the door jamb quite right. Door side was no problem.
Taking the doors apart is way easier than I thought, and even easier to put back together, luckily.
One set back... the solder I'm using simply isn't working. It won't adhere to the speaker terminal, it just balls up and rolls off and flows onto the wire only. SOOO I got the wire through to the door but can't even get the speaker wired up.
***Has anyone ran into soldering issues? Is silver-based solder not what I should be using??***
Thanks guys. Sorry for long post.
