Kyleelder
I've searched the forum and can't find any clear answers. I have a 02 4 cylinder w/Vtec and 5 speed. My car is throwing a P1259 code for V-tec malfunction. My car won't go past 4k and when i push in the clutch the rpms drop way to low and the car shudders before it idles out.while idling it feels a little rough.
My car has plenty of oil.checked resistance and continuity on the solenoid and oil pressure switch, they were within spec from the manual.I haven't pulled off the screen to clean it because i can't figure out how to get to the bottom bolt of the pressure valve without taking a ton of other stuff off. Would this screen cause the low idle everytime i press the clutch tho? Also if I reset the light and floor it i have some power from 1-3k then almost none from 3-5k and tons from 5k-redline. Then today I was driving and the oil light started flashing rapidly i shut it down.then restarted a hour or so later and it was fine.
I'm lost at this point. Hopefully someone can help
