01-03 Civic Fogs Help
AccordCoupeV6
Florida
Just finished mounting the fogs and hooked up all the wires for my 98 accord. Everything works fine except for the fog switch. Right now I'm using the switch that came with the fogs, first problem with it is that i plugged one of the wires from the switch to the fuse box and its somewhat loose, i have to give it a wiggle for the switch to work. The second problem is that when the switch works the light on it stays on, even when i turn my car off and locked it. Idk what I'm doing wrong..any suggestions ?
KO iNfAmOuS
LI
Honestly I recommend just getting.an oem switch and.following the DIY to make.it work because I'm replacing mine also. I dnt know if anyone else had this problem but its crap. It doesn't click you have to literally pull the face off the button to turn off the fogs.
Vomit_Comit
Houston
where did you put your grounds??
and there is another place in the fuse box where its snug
AccordCoupeV6
Florida
Yeah i agree on you that it is crap. I was gonna get a diff switch anyways, i just wanted to know if anyone had this kind of problem too. But thanks for the advice.
AccordCoupeV6
Florida
I ground it under the steering column where the bolt is.
Do you know exactly which one thats snug in the fuse box ?
