which wires get no power on cam & crank sensors? 5V reference?
5V is supplied by ECU, if there is no 5V it is probably shorted somewhere. Unplug everything while watching the 5V to come back. If everything is unplugged and still no 5v, you need to disconnect wire @ECU and see if the ECU is even supplying 5V, could be fried. Then check harness for short to ground before installing a new ECU.
The coils get 12V power, supplied through a relay & fuse , I think.
