01 V6 Trans Fluid Capacity( Rebuilt Trans, B&M Cooler/Remote Filter)
OldNo7_CG2
HeLL
just had the trans rebuilt on my 01 accord coupe v6 came with a new converter, i also added a B&M Trans Cooler and Remote Inline Filter just wondering how many quarts of Honda ATF-Z1 do i need to put in the trans? i will just add and check but just asking how many you guys added
CG6Lemon
Detailing Enthusiast
S.F Bay Area, CA
when i do a drain and refill it takes in about 2.7 qts. make sure ur on a flat surface as well when pouring it in so the dipstick is accurate afterwards.
oops didnt carefully proofread. sorri
lemon, dont give advice when you dont know what youre talking about mmk?
the "empty" level is 7.x quarts i believe (says in your manual). the cooler should come with instructions on how much extra fluid is required, if any...or contact B&M.
ZsleepizeZ
626 SGV
when i did my tranny rebuilt the people that rebuilt my transmission told me to put 7 quarts.
but when i measure the level of the fluid,
it was on the top of the second mark.
so i drained the fluid a little so it will be between the first and second mark:eusa_doh:
F23A1AT
Gainesville, FL
Since the converter is new it will be empty so..... a lot of fluid is needed. I would prepare to drop at least a bill on fluid alone (based on my dealerships prices) for that much fluid. But don't overfill it, that's just as bad as under filling it.
ZsleepizeZ
626 SGV
:henry:
8 quarts (on the safe side) x $7/per
how much are they charging where 7 bottles comes to a hundo? ffffffuuuuuuuuu
F23A1AT
Gainesville, FL
8 quarts is less than I expected. I thought the converters capacity was like 3 litres or something. But yeah my strealership charges like 9-10 dollars a quart.
