01 V6 Trans Fluid Capacity( Rebuilt Trans, B&M Cooler/Remote Filter)
OldNo7_CG2
HeLL
so heres the next question:
run it through the gears and i check the level with the car running or off?
finch13
Twin Cities, MN
3 liters?!? Christ.
Are you installing the rebuilt tranny yourself? It should be the shops job to fill it if they're putting it in...
Fluid change is 2.6 qts, capacity is 6.4 qt.
Just keep adding until it comes up on the mark. My guess is that you'll need 4-5 quarts. Fluid needs to be warm and engine off when you check it.
OldNo7_CG2
HeLL
the trans was rebuilt and i picked up a motor with low miles and dropped it in last week, just got done with everything today B&M trans filter and cooler and hooking up all connectors.
so 7 or 8 quarts and warm it up and turn off car check fluid ... thanks
HondaLuver83
Throw some pix up at us.
OldNo7_CG2
HeLL
2001 Accord Coupe V6
Body - 210,000k
Motor - 46,000k
Trans Rebuilt - 0,000k
B&M Trans Filter
B&M Trans Cooler
Tein S.Tech - 2inch Drop Springs
KYB Struts
New Timing belt and Tensioner, Water Pump, Thermostat, Belts, Plugs
Mobil 1 Filters and 5w20 Mobil1 Full Synthetic
New Coolant
Car needs to be washed and headlights need to be polished
