2 issues. Temp gauge, and strange sounds when I turn the eng off
natedog_37
Temperance
Ok does anyone Temp gauge start this low?
And then after I drive to work "Say 45 min or more" and turn the car off I get this. Doesn't happen around town driving that I have noticed.
Car idles like crap cold but once warm it is fine.
rooky
Heaven
Yeah I remember mines use to do that especially in cold time it take longer to warm up. The temp needle would stay cold for while and after a few minutes idling it warms up little below the way mark. But when I began to drive, it works fine. This was due to a bad thermostat in my engine. I pulled out the bad auto zone thermostat and test in on a stove top by heating it up on the flame then dip it in room temperature water( to see if it was opening and closing at the correct temp). As for the strange sound you mention I cant say because it could be a many things I'm not there to ear.
The sound is strange, pop the hood and listen there wile someone else shuts off the engine. Where is it?
With the temp gauge I also suspect the thermostat. To be sure that the engine temp is that low double check the data. Use a OBD2 reader.
