BMwiththeADD
Would like to resurrect this thread to ask nyknick1015 a question:
I assume thats a pic of your ride nyknick1015, and its a pretty sick ride. Can you say what offset and diameter your rims are?
I am trying to plus-size while avoiding the rubbing problem just like the original poster. My first go at plus-sizing resulted in the rubbing problem in the rear. Bottoming out on speed bumps or pot-holes would cause rubbing at the top of the fender. To make my case educational for others on what not to do, here it is:
CAUSED RUBBING IN THE REAR -- '00 Sedan
Tires: 215/50-17
Rims: 17x7.5 offset 40 mm
The key is that 40 mm offset. The rims I chose were also available in a 45 offset, but I think the Discount Tire guy advised the 40s because he could see that was the offset of the OEM wheels. Problem is when, you go with wider tires, you need them to "tuck in" more to avoid rubbing, therefore you need a comparably higher offset (or else modified fenders). Hindsight is 20/20 as they say,
So in my second time around, I'm doing trying to do better homework to avoid the rubbing problem. I found some 47 offsets in 18x8.5 that I am considering putting on with 225/45-18s. I just hope that gnarlier setup wouldn't effect the brakes or the tracking too negatively.
hotchef181818, did your situation play out yet?
a 225 on a 8 inch rim would fit fine.. i have a 225 on a 8.5 up front and i have no problems turning or rubbing and i am pretty slammed i would say. you wont have that stretched look tho so i dont know if your going for that
i cant really say if its gonna sit flush because that depends on your offset now
Tires: 215/50-17
