ABS LIGHT on after 5lug conversion
bostoncoqui85
New Jersey
Ok so I just had my 5 lug conversion done to my car. The car rides good but my abs light keeps on coming on and off. The issue that im having is the when the abs light comes on my car stops just fine and when it’s off it just keeps going. I know what the abs system is so I kinda understand why the car stops when the light is on. I want to know if anyone has ever had this problem when they did there 5 lug or if anyone knows what the problem could be? Just trying to get it fixed
swollen_cu
New Orleans
Check the abs sensors. They might be bad. Either that or the wire connections might be loose.
GlassJAw
New Zealand
Can you check the fault code??
I'm not sure about the USDM Accords, but when I jump the OBD2 Port connector it shows fault codes of all items with a warning light on the dash (my EPS throws a code 21 - Electrical Load summin rather)
As I said I'm not sure if you can do that with USDM 6GA's, but if you can it may help find the problem.
sickdime
NC
i know when i installed my cross drilled rotors my abs light came on , ended up being dirty. looked like it picked up brake dust and crap. cleaned it and seemed to take care of it. hope you find the problem:peace:
