CG6Lemon
Detailing Enthusiast
1-3 small bottles. i used half of a big bottle when i was bleeding all 4 corners.
with doing a brake fluid drain and fill like this, is there any specific order of draining each corner? or, just do them one at a time in any order?
also, how much fluid is expected to be purchased?
Edit: I just realized my brake fluid is BLACK. I guess I really do need a flush badly now.. I'm surprised my brakes still work perfectly fine.
That means you have moisture or a leak somewhere for the fluid to change black...
2 cents on a method I prefer:
let all 4 corners drain at the same time via gravity. Keep adding new brake fluid into the reservoir until all 4 corners drain clear.
Takes about 20-30 minutes.
* $50 is too much. I would do it for a $20 spot.
there is a specific order required, and if you do it in a different order the old brake fluid will still be in the system as you bleed/flush your brakes.
