chino581991
So yesterday, my friend was following and pointed out that my all but my third brake lights were working (the one on the rear windshield).
I've searched through the forums and figured a bad fuse, ground point, or stop lamp failure sensor were bad.
I swapped the fuse just in case but it wasn't that. I figured it wasn't the bulb because the running lights still worked and it'd be off that all 4 brake lights went out.
I know it's not the brake switch because I'm still able to shift into gear.
So all I'm left with is the sensor and ground. Do you Gus recommend checking anything else? And where is the ground and the sensor located at?
EDIT: I have a 2000 accord coupe ex-l
