car wont start,AEM EMS installed
akoutmos
Seattle
After reading a bit about stat sync'd, what it is, is the ECU check to make sure that the signal between the crank position sensor and the cam position sensor agree with each other. It should be off at stand still, but when cranking it should turn on....does it do this?
1NonlyAccord
GA
Im not sure.Im back inside. I wanted to get a few ideas to go try before going back out there
1NonlyAccord
GA
I do have the bisimoto stage2 turbo cam.adj cam gear installed..idk if that makes a difference.
akoutmos
Seattle
I think i found the issue. Fixing it now. They renamed a bunch of parameters between the series 1 ems and the series 2. Finding and converting everything is a PITA. I did all the tables and correction factors, but it turns out they also remapped the cam/crank position stuff. taking care of that now...and the fire should fire up.
1NonlyAccord
GA
Going out now with the last map,going to do the setup wizard like stated as well
akoutmos
Seattle
hopefully the VSS settings i fixed up and the crank/cam things work out okay
