Cluster filter
Dnguyen211
Iowa
I have been searching through out the forum for a thread of how to remove the ugly green filters in the cluster and where could I get some cheap white gauge faces from?
the filter on the cluster gauges is part of the actual gauge face, you have to use rubbing alcohol on the back of each one, then light will shine through in whatever color you use. a lot of people do that so they can have 100% white numbers and such. colors usually aren't affected by the filter.
if you want to put in different faces though, then there is no point in doing that since different faces sit on top of the existing faces and are lit on their own.
Dnguyen211
Iowa
Do I rub it on the front or the back? I tried it on the back of a junk cluster and I couldn't get it to come off, also is there a filter in the LCD?
