Dash lights, tail lights, brake lights wont work
Maxswell
Philly
Was installing a new amp yesterday and it didnt go well.
My running lights will no longer turn on along with my dash lights, tail lights and break lights. Everything else so far seems to be working fine. I checked some fuses and couldn't find anything wrong.
Someone said there is a box near my dash fuse box that I could've ****ed up. Just wanted to hear some opinions of some of you guys cuz you have helped me in that past.
Thanks!
james'99
East Fishkill, NY
Doesn't sound like you messed up the multiplexer. Usually, your dash lights wouldn't work if that were the case. Check your fuses. Should be a simple fix I think.
604ACCORD
Vancouver BC
Did u install a new deck? ive had issues on some cars with aftermarket decks when u use the factory ground wire it keeps popping the fuse sometimes u have to make a separate ground.
