johnnydinh701
sorry to sound like a noob, but what is the air/fuel ratio gauge for
retroshark said:no offense but vtec isnt that important any more. most car companies have their equivilant (BMW, Mercedes, Toyota, VW) in fact, hondas vtec (Variable Valve Timing and Lift Electronic Control) is now more outdated compared to systems such as toyotas VVTI. you could add a light for VTEC but even in the cae of the write up on that site, it has no purpose. unless you are runnig a "vtec controller" or you have full enginemanagement and want to set the rpms at which vtec engages, you really dont need a light to show vtec. even if you just want to know you are "in" VTEC, it still makes no difference because you cant really do anything to change it. back when vtec first came out it was the top of the line engines at honda that had it. now, every honda has it, and more omportantly, it has been refined. most cars actually have the same system but under a different name.
yellowfever said:...... and ill mail you back a tampon which u can use in its place. vtec? yes please!
yellowfever said:if u had a bimmer or benz then i dont think you would be bragging about your valve timing of all things and if you have a toyota then you proboly have a subscription to "martha stewart living" and if you have a VW then ur to busy saying "V Dub yo". So for those of us who love our hondas (not you obviously)and have dreams of them ruling the streets then yes "vtec" will always be our battle cry! And if you dont think that then go tear your solenoid out and mail it to me and ill mail you back a tampon which u can use in its place. vtec? yes please!
Sketch o5 said:volkswagen owners dont go around saying that....just so you know, and do you really think supra owners have a subscription to martha stewart living? haha.
amen brotheraackshun said:Yes they do, my friend has a Passat and says it about every other sentence, so everytime he says "V-DUB yo" I say "VTEC YO!"
Well does "O" count for martha stewart living? If so then, I know two supra owners (3 if you want to include the girl).Seriously, I'm not kidding.
And yes VTEC may be old but it's fine with me, who says all new things are better anyways? and since when does old things suck? (I'm not saying the VTEC in the 6thgens are the best thing ever either).
Those guages really dont even tell you anything. Ive heard they just bounce around. If you need a wideband o2 reader check out 14point7.com I use it and it works great
These will not work on ULEV. When I tried the took hook up the blue wire mod in neo this is what i found out. The o2 sensor sends 2 voltages to the ecu. I believe the ecu uses the differences between the red and the blue wire. When I hooked up a volt meter to the each wire while the car was at idle the red wire would had an output of around -1.75v and the blue wire would whould have an output of like +2.2 volts. take the difference and it gives you .45. stoichiometric . When I messed with the tuning and make it run rich and lean, the red wire was usually the one that changed voltages. but some times they both changed.
If you really want to hook one of those up on a ulev car, then you could use the cat o2 sensor. Those guages really dont even tell you anything. Ive heard they just bounce around. If you need a wideband o2 reader check out 14point7.com I use it and it works great
