rotary_powered
Here's my guide to making a license plate bumper bracket. Mine screws into the bottom of the bumper, but I'm sure you could mount if on the frame if you wanted.
Finished Product
What you will need:
- 1/4in x 3/4in bolts (4)
- 1/4in nut (4)
- 1/4in flat washer (10)
- 12in 18gauge ZMAX Strap Tie (2) -- Home Depot SKU #MSTA12Z -I found near the construction supplies
- My total home depot cost was $4.16!
- Sharpie
- Sheet metal Brake or Sharp corner to bend on
- Ruler
- Drill with 1/4in drill bit
Step One:
First, you will need to get the two metal strips, and compare them to your license plate like so, the large hole should line up with the bolt holes of the license plate easily.
You will then want to draw a line to bend it on, and draw another line the same distance down on the other. Mine were about 3-1/8in from the end.
Step Two
Next you will want to bend the two sheets of metal. If you have access to a sheet metal brake then use that to bend down both strips on the line. A large vise and hammer would work well as well. I didn't have one available, so i used the edge of a workbench and just pushed it down.
Try to get them as close as possible, but they don't have to be perfect
Step Three
The next step is to attach the brackets to the license plate.
The order to use is front to back
Bolt-Washer-License Plate-Bracket-Washer-Nut.
Then line them up and tighten them up.
Step Four
Next, is to attach it to your bumper, My bumper is zip-tied on so it was quick to remove, you may not want to.
Find where you want to mount your plate, and drill a quarter inch hole through the other large hole on the strip.
I also drilled a small hole at the end so I could zip-tie it for extra support, turns out it isn't necessary.
Step Five
Next, you will want to attack the bracket to the bumper
The order goes
Bolt-Washer-Bracket-Washer-Bumper-Washer-Nut
Do this twice, once for each side, and your done.
Then just mount your bumper
And your done!
You can mount this anywhere along the bumper that you would like, and could also hang the plate from the top if you'd like.
Let me know what you guys think, If there is enough interest I'll put up a tutorial for my Nexus 7 in-dash install.
Finished Product
What you will need:
- 1/4in nut (4)
- Sharpie
- Ruler
Step One:
Step Two
Step Three
Step Four
Step Five
The order goes
And your done!
