DIY Throttle Body Bypass
1NonlyAccord
GA
my 99 ex didnt look like this,nor did the 1/4 splitter work and 7/32 stuff was way to small.
Had to use 5/16 vac caps and clamps..along with re-using the metal pipe just connected it together that way.
hopefully itl work the same.ha
J30MAN
Agawam, MA
those parts may differ from the 98-99 j30 to the 00-02 j30, because i know the spark system is different in both.
1NonlyAccord
GA
I did this on my f23 4cyl..maybe thats why its different.ha
1NonlyAccord
GA
maybe the OP should clear that up..i wasted $ on buying the wrong stuff..and made 2 trips almost 3 to oriellys.to get this mod correct with no leaks.
so for 4cyl- Needs 5/16 brass splice
along with 5/16 vac. caps
the clamps mentioned above worked.
CG6Lemon
Detailing Enthusiast
S.F Bay Area, CA
I made a thread about this couple weeks ago.....
1NonlyAccord
GA
sorry..did not see that.But yes now i know after $ wasted and time.
jwong512
Socal 626
Yeah, Lemon made a post about this awhile back and I remembered reading it before I did the mod. Oh well, lesson learned, 4 cylinder parts and V6 parts are different.
intel0116
SoCal
very cool theory, but i have one doubt, ok so the anitfreez/coolant is there to keep it from freezing shut so you dont really need it if you live in a place that dosent get below 32 degrees, but what about when temps get high dosent it act as a coolent for the air going in ?
