First off, you cant use the accord ecu. It simply wont run right and you will probably blow the motor with it. That would be the first thing I'd fix. You need a p13/p28/ or p72. As for the idle, Id first look for vacuum leaks, then Id take the fast idle control valve apart and fix that. It is most likely the reason your idle is hunting when warm.
