F20b Knock Sensor Location
jponder4
Atlanta, GA
I have almost everything wired in but I cannot find a place for the knock sensor. I don't think the F20B has a knock sensor, but is there I place I can add one from my f23a1?
If it has one, which is very well might not being that it's from a different country, there should be a spot on the back of the block near the filter that you can drill out.
FYI - if you're going OBD1, you don't need it. If you're staying OBD2, you will need it.
jponder4
Atlanta, GA
I looked back there and didn't see an available port. I am planning to stay obd2. Do you know if I can just tap a hole that is unused that is near the oil pan. Ill try to post a pic when I get home of where the hole currently is.
jponder4
Atlanta, GA
You did, but to clarify, the hole is considerably lower than the oil filter. I should have said can it go anywhere in the block or does it have to be near the placement on the stock motor?
nathan007
Montreal
the F20b engine (at least 97-00) DOES have a knock sensor, it's located right under the head,under the intake manifold. It may be broken off tough.
Green plug above oil filter in this pic:
the one under the oil filter is the oil pressure switch
