Hi All,
Unfortunately Im new to this forum and just finished the most monumental install (4 weeks part time)....(for the whole system though)
I installed Nakamichi 6.5 components in the front, now getting the actual speaker in was horrific because well...its too big. I had to make a new weather sheild new mount, shave down the door all so i could get this thing to clear the window by 3mm GAH!
With that done though I decided to install the tweeters into the OEM dash locations and it was easy, very easy...heres how.
Step 1
Pop the fabric thing up with a screw driver wrapped in electrical tape. I keep one wrapped up and use it for everything.
Step 2
cut the wires as long as humanly possible, by unhooking the wire from the bottom of the tweeter you can get an extra 20mm or so (Im an Aussie METRIC ROCKS!! 1 inch = 25mm)
Step 3
Unscrew the tweeter from the bracket. DO NOT take the cloth thing of first or you will no be able to crack the screw for the tweeter without breaking stuff.
Step 4
Take all the protective meshes off your tweeter, at least for the Nakamichi soft dome this made it quite compact.
Step 5
glue the tweeter to the bracket. This sounds dodgy but seriously it is the best way. The vibration and forces are puny and there are often no screws on your tweeter to use by this stage.
Step 6
Screw the bracket (now glued to your tweeter) to the cloth thing, solder the wires and pop it back in.
Finished!
There is one complication though, the wires are split somewhere where you cant get at them, I ran new wires out my doors (really hard) so then it was just a matter of dropping the OEM speaker wire into the tweeter terminals on the cross over.
Lesson, just put smaller speakers in the door and live a long and happy life.
