Ofnir107
Hey guys,
I'm looking to gather some information before I start this project. I'm planning to use the OEM fog switch to turn on a rear fog light in my tail light. My plan is to use my driver side reverse light and wire that up to the switch. I've had some close calls with cars almost running into my rear. I would like to do this to hopefully prevent someone from hitting me in the future (esp with all the idiots out here in the winter).
I'm going off of this diagram and info that I searched. I have several questions (I have yet to do any type of wiring on my car)
My questions are:
1) The reverse light harness has two wires coming from it, a green and a black wire. I'm pretty sure the green is for power and black for ground. Can I just connect the green wire to the green connection "output to relay" on the switch and the black wire to the red/black connection on the switch to make this whole set up work? Or would there be some additional wiring I would have to do?
2) Which would be the closest wire to tap near that switch that turns on with the parking lights?
3) Is there a specific gauge wire I should be using when I'm running the two wires from the rear of the car to the front?
4) Finally, is there a DIY someone can point me to involving the removal of the interior side panels? I couldn't find any for removing the panels where you step over to get into the car. I'm planning to run the wires from the rear of the car through there.
Again, I'm not very experienced in wiring but I figured this might be a chance to do something on my own for once. If there is a flaw with what I'm planning to do, please let me know so I can figure something else out. Thanks in advance guys.
Black -- Ground
Green -- Output to relay
Blue -- Vcc2 (Power coming from the ignition, all that is needed is a power source to activate your relay for the fog lights. Hook it up to the ignition and your fog lights will turn off when you take the key out)
Red/Black -- Ground
Red -- Vcc1 (Power coming from the parking light or any light that comes on when you turn the lights on so it'll light up your switch when you turn on your lights)
My questions are:
