H22 ecu
Tkeefe480
Vermont
Hi, I was told that my stock accord harness will plug into my h22 ecu is this true if not what ecu would I have to get?
I mean, certain plugs may be similar and physically will plug in, but they will not be wired correctly.
If you're doing an H22 swap or already have, you'll need the H22 ecu and have to swap some pins around on the factory accord harness to where they match up on the H22 ecu. There are several write ups on how to do this.
Tkeefe480
Vermont
So the prelude ecu will work with the accord harness I will just have to re pin the harness?
