Help with 5 lug conversion
Turbo5upra
NY
Dumb thought here (not sure why it took me so long :p) drill em if you are swapping hubs... No need to get the nub out if you aren't reusing the hub.
You gotta drill them to use an ez out anyway.
Xxtankinover
Long island NY
so i got the impact driver and got 2 rotors out, one i got one screw out the other is decently stripped, and the other front one both are stripped i guess from all the rust the impact driver was doing more harm than good, now i guess only way to get those screws out are drilling them out right?
Xxtankinover
Long island NY
i was hopping i could re use the hubs but that looks like its not going to happen right? if i cant reuse the hubs if i drill them out i might as well get the hub and rotor off and just use the assembly and get a new hub i have new rotors in the way.
When you drill them, just do the top. They are m5, I think, so something like m
5.5mm will work, aka 1/4". Once the rotors gone vice grips will work, or the new rotor can go over it. Call it a 'Locating Pin'.
Igor
Under construction
Florida
Like $9.99 at autozone, crappy quality tool but worked for me...
Turbo5upra
NY
If you're doing a 5 lug swap the drilled screw won't be an issue-
