unrealistik
I'm about to install a relay to my fog lights using this diagram:
My question pertains to the wire that is going from the Switch to the Fusebox/IGN/Battery power. Is it okay if i ground this wire? or where is the easiest place to tap it into. I am okay with the fog lights being able to turn on and off even when the ignition is off. just want whatever is easiest.
thanks
thanks
